High Quality Monitor Suggestions
xFeaRDom
Estimable
So I'm currently running a triple-display setup, with 2 BenQ 21" Monitors, and 1 32 Inch TV. I am looking to get rid of both of the BenQ Monitors and replacing it with a high quality, maybe IPS monitor to play games such as Far Cry 4 and High Quality games. I do not play FPS games so response time isn't a big key.
I am currently looking at the Asus VC279H:
https://www.asus.com/uk/Monitors/VC279H/
My Budget is around £150-200, and I would preferrably not go over the budget, but a slight increase may be needed. And if possible, a monitor around 27" would go well, and probably the lowest I would go is around 25". I would prefer 27" though.
Thanks in advance.
- Dom.
Oh right, don't really know too much about monitors, was just a suggestion. Any chance you could find me a similar monitor if possible?
Been looking on the overclockers website, found this monitor which seems pretty good: https://www.overclockers.co.uk/aoc-i2769vm-27-1920x1080-ips-widescreen-led-monitor-black-mo-025-ao.html
And this one on a different website:
https://www.shop.bt.com/products/aoc-q2577pwq-25--2560x1440-5ms-ah-ips-vga-dvi-hdmi-dp-monitor-q2577pwq-BVWG.html?refs=460500000
In addition, this monitor which is from Acer...
My setup is a little weird. I have the 'Box Room' of the house, so there's basically no room at all, so I have my TV on my wall so I can watch films and things while laid in bed and things like that, and then the monitors are for up-close and gaming, and the monitors are on my desk, below my TV. If I had room for 3 monitors on the same desk in a great desktop setup and had different sized monitors, that would bug me immensely.
Thankyou for the feedback :)
I've been looking, would this monitor be better, especially for the price? It is still IPS but it is 2560x1440, and still 27"
http://www.ebuyer.com/735520-exdisplay-hannsg-hq271hpg-27-2k-wqhd-ips-monitor-ebr3-hq271hpg
Personally, this looks really similar to the Asus monitor, but the 2K definitely steps it up for me, but has a 7ms response time over the 5ms the Asus has. This shouldn't make too much of a difference because I don't really play FPS games.
In addition, this monitor which is from Acer: http://www.newegg.com/global/uk/Product/Product.aspx?Item=N82E16824009626
Thanks again!
- Dom.
