High RAM usage while nothing is running! HELP!
Luke_Live
37
So my computer occasionally blue screens. This is common. I need a new mobo and CPU probably. But today I left to go hang out with friends, and I left my pc on. And I came back and it was on the login screen. BSOD I assume. No biggie though. Tey usually don't cause too much problems. They are just annoying. Then I try to play csgo. It wont open. I ended up fixing csgo, just to notice on task manager that I have 7.3/8 GB of RAM being used. This is NOT normal. All i had open was steam and CSGO. I restarted my pc Multiple times, but to no avail. So I checked Task Manager and nothing added up to even 1.5 GB. Odd. So I did some research. Scanned my pc with Malwarebytes. Nothing found. Scanned with TDSSkiller to scan for Rootkit. Found nothing. So Malware seems to not be an issue. But whats using all my RAM? Am I having a memory leak? Also my HardDrive is at 100% Usage. As of writing this RAM has gone down to normal usage, then right back up to 6 GB and now is at 4 GB, with only google chrome open and some background tasks. Please Help me solve this!
Specs:
CPU - AMD FX-8350 8-Core Processor @4.00 GHz
CPU Cooler - Cooler Master Hyper 212 EVO
GPU - GeForce GTX 650 Ti 2GB
RAM - Corsair Vengeance 2x4GB PC3-12800 DDR3
HDD - Western Digital Blue 1TB
SSD - SanDisk Internal SSD 120GB
PSU - Corsair CX 600W 80+ Bronze Certified Simi-Modular ATX
Case - Corsair Carbide Series SPEC-02 Mid Tower Gaming Case
Motherboard - Asus M5A97 LE R2.0 ATX AM3+ Motherboard
OS - Windows 10 Home 64 Bit
(I added everything, cause why not 😛)
Screenshots:
Task Manager
https://gyazo.com/27b2936b8b4f086e3fb5ca055be7b35f
Resource Manager
https://gyazo.com/bc85a2a565bf602edc65b566fa9581b0
Also the free keeps going lower and lower and is now at 4 MB
Thank you!
download and run rammap
https://technet.microsoft.com/en-us/sysinternals/rammap.aspx?f=255&MSPPError=-2147217396
then go to the empty menu item, you can empty the stanby memory, working set and other cache.
it should make the system go back to a clean state with no apps preloaded into standby memory.
My non-paged pool is low, so i didnt think this was the reason. I will try that though, also I have restarted many of times, and to no avail.
Windows takes 5 hours to preload apps? Cause it comes, and doesnt go away. It went away the first time after HOURS of research, now it wont! And I REALLY want to play the battlefield 1 open beta!!!! (cause i got the insider access)
Reactions: bryanperez6119
