Question High Ryzen 5900x Temps
Frozenjello_7
8
Hi, I have a ryzen 5900x and a EVGA 1080ti FTW3 with a corsair h100i elite capellix and im getting very high temps. I am getting about 75 celcius idle and 90 degrees playing apex. Its only 20% under load on task manager while playing apex.
Just checked, All my wires should be plugged in correctly, how do i know if the pump is working correctly?
While under load - Cinebench R23 thermal test is a good one - feel both tubes.
If fluid flow is good, you shouldn't notice too much of a difference between them.
If flow is poor, you should clearly be able to tell, "Hey, this one's warm, and the other one is pretty cool."
I was literally writing the same thing but you beat me to it, kudos!
