Hello's,
I have the EVGA GTX 770 SuperClocked with ACX Cooler ( http://www.amazon.com/dp/B00CZIQXBA/ref=pe_385040_30332200_pe_309540_26725410_item )
I'm seeing (seemingly) high temperatures when playing games. Specifically Bioshock Infinite the GPU Temp spikes to 90C and hovers around 80-85. The fan kicks in to 70%+ and it is definitely not quiet. I built this PC with the hopes of a quiet build.
I was wondering what options I have of getting a liquid cool kit for this card, and if anyone has any experience doing this. Does it significantly reduce temp? What about noise?
I'm looking at http://www.sidewindercomputers.com/xsragtx770fu.html?gclid=COfuh4yr3bsCFfPm7Aod_0UAUw --- but I'm not sure if it'll fit my card. Does "NVidia GTX 770" include my card?
Thanks for any help
[Also, I believe I have sufficient case cooling. One front pulling in. One bottom pulling in. One top pulling in attached to radiator for CPU. And one on the back pushing out. I've also tried running games with side panel completely open and the ambient room temperature at 70F.]
Thanks for any help
