I've been having issues with my 3770k for the past few months. Using Intel DZ77GA-70K mainboard and Corsair 500R case. Ambient temp in the room is around 25C. I'm running stock settings in bios. My temps during basic web surfing range from 33C to 42C which are very close to what they run at idle. Running prime 95 shoots my temps up to high 80's low 90's. I have tried this with the corsair h100i and recently the enermax liqtech 240 both with the same results. The stock intel cooler runs in the same temperature range which is what I find weird.
I've been using artic mx-4 paste without any luck and have tried reseating the cpu block multiple times, applied only a rice sized dab of paste, pea sized, and spreading it out manually all with similar results.
I'm at a loss at what could be causing this. Below are SS of my system idle and under load. Any help would be greatly appreciated.
Idle
Load
Idle
Load
