Highend Pc, So many Crashes system not running good, i need your Help!
Aschuram
Hello everyone!
I really really hope that some of you guys is able to help me i am getting really desperated.
First of all this is my Full build https://www.reddit.com/r/buildapc/comments/567xqw/last_check_please_first_gaming_pc/ .
My Monitor is an Acer XB270HU and my SSD Is a Samsung evo m.2 850.
I will explain you now my Problems and please stay with me, i own this PC now for 4 Months and no one could ever help me since then.
I do own Windows 10 Education version 64 Bit.
Okey so lets go.
All Drivers are up-to date, if necessary tell me some programs, which will show you all my current driver informations and I will let you know !
So for example lets come to gaming:
I play CsGo and I know that this game is more CPU based, than GPU, but still with an Intel core i5 6600k I should get some good Fps right?
So I can tell you that i maxed out the graphics at Wqhd (2k) and I am playing with 80-130 or sometimes 110-150 fps.
Now the thing is, even if I lower the graphics to the LOWEST settings, it won't change anything in my fps numbers.
Also ALL the times, when i press ESC and try to open the menu, the whole game stutters and the sound laggs for a second and then I am able to go to the menu.
I did not lock any FPS and vertical Sync is disabled because i have a g-sync monitor which can deal with that.
So I do have low FPS in that game, in Benchmarking of Graphic cards, i tested my rate with a friend and we got almost the same numbers so my graphic card is okey (Gtx 1080 MSI).
Secondly, when I tab out of games which are played in Fullscreen mode (for Example Rocket League, CsGo or even Black ops1) I am getting most of the times a black screen where I can't do anything expect hearing sounds. When I re-tab in the game and close the game afterwards, i get a black screen and can't do anything so I have to force a reboot.
Now comes the most annoying part and I hope there will be some people who can understand this.
Like I said I do own an 144 HZ Acer Monitor, which is awesome, dont get me wrong.
I tested the monitor at a friend and everything was working fine!
By that i am talking about the "SMOOTHNESS". If you guys ever used an 144 HZ Screen you will know what I am talking about.
When you move your mouse it just looks amazingly smooth and for example if you drag a folder (right in your windows desktop) around, you see how amazingly smooth the animation is and that you are even able to read the content of the folder.
BUT !!
When I was using the properly working Screen at my PC, it definately was not running as smooth as it was before.
I have enabled 144 HZ obviously and G-Sync in Window and Fullscreen mode, and it does run smoother than a regular 60 HZ screen, but it just does not work as it should be !
And it can not be the Graphics card, because I even tested the graphics card from my friend where everything was working fine, but in my PC connected, it didn't change anything !
I can not explain what is causing this micro lags all the time and why it is happening. I also can not find any kind of solution in the Internet and this is why I am praying that someone of you guys is able to help me I would be so incredible glad !
Let me add one MSINFO with that topic so you can already see what kind of components and drivers I have.
I already installed windows 3 times new, with a completely clean install but it did not change anything.
Please let me know if you need any kind of Information else !
Thank you so much guys!
First let me say your GTX 1080 video card is way to powerful for a 1080p monitor even at 144hz. Your fps should be buttery smooth. It could be your video drivers if your using Nvidia's newest. Try uninstalling the Nvidia drivers in control panel and use DDU to remove all nvidia configs. Then download the older 373.06 drivers. Drivers 375.xx and later have been badly bugged causing all kinds of problems. Locking video memory on low, to crashing the OS, and possibly the cause of your black sreen issues. Below is a link to the Nvidia driver archives so you should get a list of about 10 drivers versions to pick from.
http://www.guru3d.com/files-details/display-driver-uninstaller-download.html
http://www.nvidia.com/download/find.aspx
Hello Elbert, my Monitor is not a 1080p monitor its a Wqhd Monitor, but yes you are definately right ! Even for 2k and even for just CsGo it should run buttery smooth !
I will listen to your advice and remove the drivers now and install it new
Update.
I uninstalled all the drivers with DDU and reinstalled the version 373.06 but it dit not change Anything at all.
Still 80-130 fps only and my windows is still not running smooth.
