Hey all,
To preface this, I know AMD CPUs run high voltages and that it is normal behavior, especially in idle or lightly threaded loads. I do not need to see multiple comments telling me "that's perfectly normal voltage and temp levels, stop whining". However, I am pretty certain that my case is not normal.
Here are some details for reference:
I attempted to make some changes in my BIOS to reduce temps, but almost nothing made any difference. I even completely reset my BIOS settings to default, only changing a few things unrelated to CPU performance and I got the same temps/clocks/vcore as I did when running WITH PBO ENABLED.
Screengrab of RM at idle (waited for temps to stabilize): View: https://imgur.com/a/BAAm7hu
You can see here that none of the cores are sleeping for some reason despite no foreground apps and minimal background apps (~2% CPU usage), and the most powerful core in CCX 0 is boosting to 4GHz with default OC/PBO settings.
I'm not sure what to do or what to think here, is this a problem with the chipset driver? BIOS setting? Windows update? Rats nibbling through the wires in my PC? All I know is that I need to resolve this quick because I am boiling alive with my PC on and I will not make it through the rest of the summer like this.
Thanks
- AMD Ryzen 5 3600
- Asus ROG STRIX B500i GAMING
- Corsair iCUE H100i ELITE CAPELLIX
- 2xCorsair LL120 (mounted in push as front intake)
- Chipset version 4.06.10.651
- BIOS version 2803
- Ryzen Balanced Power Plan
Thanks
