HIS 9800pro artifacts help
pg666
7
I'm getting artifacts at default settings with most games.
If I o/c my ASUS m/b by more than 10% the boot fails unless I unplug everything. Could the artifacts be caused by a struggling power supply?
Struggling power supplies usually just plain crash. More likely it's a heat problem, which would also affect your general stability and CPU overclocking.
What are your temps?
And what is your PSU?
________________
<b>Radeon <font color=red>9700 PRO</b></font color=red> <i>(o/c 332/345)</i>
<b>AthlonXP <font color=red>3200+</b></font color=red> <i>(Barton 2500+ o/c 400 FSB)</i>
<b>3dMark03: <font color=red>5,354</b>
Have you tried downclocking your memory? I had similar problems on the HIS I bought; finally tried d/c'ing the memory and the problems went away at 300. Just got unlucky with the memory on that card, so I RMA'd it.
Temperatures of max 55 on the CPU and 40 on the mb. The PSU is 350. I suspect the psu because there are times when I go beyond +10% on the cpu that the system fails to boot unless I disconect all USB devices
55 seems a bit high for a CPU running at stock, what kind of CPU do you have?
If you know your PSU is that iffy then you should indeed replace it with at *least* a good name-brand 350 watt job, preferably 450 watt. If you can't afford name-brand then go at least a generic 500 watt PSU.
________________
Seems high to me, but I'm an AthlonXP guy. Any P4 overclockers can tell this guy if he's running hot?
________________
