Hisense Chromebook color display problem
rooster2
Somehow color display changed to black, white, and gray. How do I restore full color??
Thanks for any advise.
Hi,
It seems like that laptop switched to High Contrast mode that may it's display black and white. Please do try these steps that may help.
- First, click on Settings then click on Show advance settings and you'll find Accessibility.
- Under Accessibility remove the check on "Use high contrast mode" then save the settings,
- Do test it again after changing this option.
Hopefully this will help. :)
rooster2
Thanks for your advise, which fixed the problem. The setting was switched to High Contrast mode. I removed this setting, and color is now back to normal. I could not find a "save the setting" button. Maybe my Hisense Chromebook doesn't have one. Guess I will learn soon enough upon reboot.
Thanks again.
