HK AVR85 receiver problem
Juan
168
Archived from groups: rec.audio.tech (More info?)
I have a HK AVR85 surround sound receiver. The volume isn't
working correctly anymore. It is Either of two settings. Very low
volume or BLARING loud. Its variable adjustment doesn't work at this
moment. I tried to see if the microprocessor would reset after 2 hours
by unplugging it, but it didn't. Is resetting the micro processor the
answer, and if so, how is that done on this model? Thanks in advance.
G
Guest
Guest
Unlikely any "reset" is going to fix this. It has a real live problem, and
needs a real repair job. Some bad IC or other I would imagine. If it's not
worth spending possibly up to 150.00 or so on the repair, you might consider
replacement.
Mark Z.
"Juan" <user@att.com> wrote in message
news:1gaqp0ht621joe8jccedb95pi5kpkrg1lu@4ax.com...
Juan
168
On Thu, 18 Nov 2004 20:00:34 -0600, "Mark D. Zacharias"
>replacement.
>Mark Z.
Thank you.
Probably good for target practice.
G
Guest
Guest
news:ejjtp09feqgmjlb8ibvnfhe8sajc76115j@4ax.com...
>>consider
>>replacement.
>>Mark Z.
> Thank you.
There's always eBay. Might get a few bucks for it.
Mark Z.
