Home Built Computer problems
BlueHoplite
12
I have built a home PC about 6 months ago. Here are the specs
AMD2 processor FM1
MSI motherboard - MSI A75MA-G55 AMD A 75 FM1
8GB 1333 MHZ MEMORY
500 GB HD
First 6 months went ok until, I installed a wireless pci card. I took off the metal plate slot to install the pci card then carelessly left the metal plate to cover an open slot forgetting to screw it in place. My wife then moved the pc to another place and placing it on the floor. Our floor is carpeted. My son, whom I built the computer for, turned it on and first he sees the blue screen of death, then after restarting the machine several times, there is virtually no display at all on the screen. I then got the HD and and connected it to my PC and it booted for a while until the Windows 7 animation logo starts and freezes. I then backed up the files inside the hard to another HD storage and formatted and installed a clean OS of Win 7. It looked ok on my pc. I then transferred the HD to my son's pc and started it. Still no go...no display on the screen. MY msi MB has a built in video display card. I am suspecting that the MB is damaged because of the metal plate that I failed to scrw back fell on the MB and probably did some damage or the fact that the PC was on carpetted floor and static electricity is the culprit or a combination of both. Please advise what to do.
thanks
chulex67
801
Do you know the Name of the Cpu? Does it gives you any error with the blue screen?, Its possible it discharged static on the motherboard. Do you have 2 Sticks of ram?. Does the computer Starts but gives no video signal?
BlueHoplite
12
Hi
CPU name is Amd fx80.
The PC has a pair of rams
Yes the PC runs but I virtually see no display at all except for flicking blue line streaks
At some point when I restart but more often no display at all
Thank you
BlueHoplite
12
I am at a point of giving up as I have tried all possible means to fix my machine. I have never encountered a very difficult PC to fix.
After turning on the machine, either a browse the net or even just scrolling through the c drive my computer crashes several time (between 2 to 4 times) and get the blue screen of death. (see message)
Problem signature:
Problem Event Name: BlueScreen
OS Version: 6.1.7601.2.1.0.768.3
Locale ID: 1033
Additional information about the problem:
BCCode: d1
BCP1: FFFFCE803C8A9CF0
BCP2: 0000000000000002
BCP3: 0000000000000000
BCP4: FFFFF880016661C7
OS Version: 6_1_7601
Service Pack: 1_0
Product: 768_1
Files that help describe the problem:
C:\Windows\Minidump\080813-49327-01.dmp
C:\Users\apoach\AppData\Local\Temp\WER-70871-0.sysdata.xml
Read our privacy statement online:
http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0...
If the online privacy statement is not available, please read our privacy statement offline:
C:\Windows\system32\en-US\erofflps.txt
My computer specs as follows:
AMD A6-3500 APU with Radeon HD Graphics with built in Audio
Asus F1 A75-V PRO MB
8 GB 1333 Ram
Windows 7 64 bit
500 GB HD
I have tired all the diagnostics and test that Windows 7 has and no error on memory but when I chkdsk the harddrive after going thru the 2 of 3 it crashes. Please need help. I am at a point of giving up already. Mnay thanks for any advice or help
BlueHoplite
12
I have already replaced my son's pc with a new 600W power supply as I found out that the 500W that he has is underpoered. But see my previous post of what is currently happening. Very frustrated now =(
