AwakenSoul
11
Hi Guys,
I'm looking for decent gaming RIG not very costly.
I Have a budget of about 40000-50000 INR Around 720-850.00 USD
Please note that I intend to buy my components from India which would make them about 30% costlier that what is available on newegg. I have posted the new egg prices as most ppl have used that as reference for this forum
Need to know if I can get any other component to save cost and still play games without over heating my system. Do not want to overclock.
What kind of a cabinet should i get.
Also would like to know if the system would survive atleast 2-3 years of use without any problems. I cant afford to spend like this every year.
I normally play games C9, League of legends, and games like NFS and Assasins Creed,
MAX Payne 3. I want a system that could support new game release for the next 2 years atleast.
Processor: AMD FX 4100
cost: 110$ NE, 6600 INR
MotherBoard: ASUS M5A97 ATX AM3+socket AMD 970 Chipset
Cost 100$ NE, 6700 INR
Graphics Cards: Asus NVIDIA GTX 560 Ti 1 GB DDR5 Graphics Card
Cost: 220$ NE, 16000 INR
RAM: Corsair Vengeance DDR3 4 GB (1 x 4 GB) PC RAM (CMZ4GX3M1A1600C9). will increase to anither 4 gb after a couple of months
Cost: 25$, 1700 INR
HDD: WD Caviar Green 2TB HDD ---Not on New egg
Cost: 6200 INR, Approx 111.00 USD
PSU: Corsair CMPSU 600W
Cost: 5300 INR 95.00 USD
The total cost for the above components totals about 43000 INR or 655.00 USD.
Your build will work.
You have correctly budgeted 2x the cost of your cpu for the graphics card. My rule of thumb.
The graphics card is the most important component for the gamer.
As an option, consider a Intel i3 of some sort instead of the FX-4100.
Intel has faster cores which help more than added cores. Read this, for instance:
http://www.tomshardware.com/reviews/gaming-fx-pentium-apu-benchmark,3120-6.html
A G860 or i3-2100 can cost less and be just as effective.
Without overclocking any socket 1155 motherboard will do. H61 based motherboards can be very inexpensive.
Buy your 8gb ram kit up front.
Ram is sold in kits for a reason.
Ram from the same vendor and part number can be made up of differing manufacturing components over time.
Some motherboards can be very sensitive to this.
That is why ram vendors will not support ram that is not bought in one kit.
Although, I think the problem has lessened with the newer Intel chipsets. Still,
it is safer to get what you need in one kit.
If you go the AMC FX-4100 route, you will want two sticks for dual channel operation and DDR3-1600 ram. AMD is sensitive to ram speed.
If you go Intel, which has a superb ram controller, the needs are less, and 1333 ram will perform equally as well.
A cabinet(I call it a case) needs to be large enough to hold your motherboard and parts. Past that, it is one of the better places to economize. Antec makes good quality cases that are reasonable. Look for the 100.200/300 series.
AwakenSoul
11
Thank You for the reply!!
I checked the Intel I3-2100.. changing to the I3 and getting a compatible mother board that I like is Increasing the total cost of my system by around 5000 INR which would leave me a little short on cash while choosing a cabinet (case for the components)
That surprises me. Can you provide a link to where you might do your shopping?
AwakenSoul
11
I use the below sites as a reference!! I checked the Intel I3-2100 and the I3-2120.
How ever I will be checking my local It market for prices before i decide to buy.
http://www.flipkart.com
http://www.theitdepot.com
The 2nd 3rd gen I3 processors need a H77/Z77 chipset to work well. All the ASUS boards in that ranges are 10000 INR plus.
I am a little biased towards ASUS boards cause i have used 1 for the past 3.5 years without any problems.
Using the first link, I see a 2120 @7197, which is even faster for less than the 2100.
http://www.flipkart.com/intel-3-3-ghz-fclga1155-core-i3-2120-processor/p/itmd8k45juy3gv6j?pid=PSRD8K44HQJ6HPYR&ref=e975b37d-a8d6-4233-b4fa-02c24d80eb9a
For a motherboard a H61 chipset will do, and a Micro-ATX will do also.
The ASUS P8H61-M LX @ 3021 will do the job.
http://www.flipkart.com/asus-p8h61-m-lx-motherboard/p/itmd5ppvvz2pjkwe?pid=MBDD5PPVTRZZKZYS&ref=5a86d292-6fb4-41ff-a87f-449155d452c1
What you lose with H61 is no overclocking of a "K", and 4 expansion slots vs 7 for a full atx motherboard.
Here is a link to what each chipset gives you:
http://en.wikipedia.org/wiki/LGA_1155
The total is 10218 which is less than your original total of 13300 for fs-4100 + motherboard.
And that is just from site#1.
Strange #1 has no stock of ANY Antec cabinets.
Site #2 has a Antek VSK-2000 for 2350:
http://www.theitdepot.com/details-Antec+VSK-2000+Gaming+Cabinet_C5P5909.html
AwakenSoul
11
Check the below config I was working on
Motherboard: Asus P8Z77-M 32GB DDR3 Intel Motherboard 10735
Processor: Intel 3.3 GHz FCLGA1155 Core i3 2120 Processor 7197
Garaphics C: Asus GeForce GTX560 Ti 1GB DDR5 Nvdia PCI E Graphic Cards 16990
PSU: Cooler Master Extreme II 625W Power Supply (RS625-PCARD3) 4125
HDD: WD Caviar Blue 500GB SATA Internal Desktop Hard Drive 3925
RAM: Corsair Value Select 4GB X2 1333 MHZ 2360
Cabinet: Nzxt Beta Evo Mid Tower Black Steel Cabinet 2700
This would cost me 48032 INR and If I replace that with the Micro ATX board i Would get it for 41000. INR Means I could still get the 2 TB HDD
