Home premium x64 to Pro x34
mudhugger
Hello,
I am attempting to install an Autocad release 14 program on Windows 7 Home Premium (x64). My understanding is that I should update to Windows Pro, and use the XP option. Is the XP option compatible with x34? or do I need to get a Pro x34 and do a clean format? I also heard that downloading an Oracle VB binary exe for windows hosts will work. Is this correct?
there is an "xp" option.... It's available with Pro, Ultimate and Enterprise and is intended for use on programs that were designed to run with windows xp.
http://windows.microsoft.com/en-US/windows7/install-and-use-windows-xp-mode-in-windows-7
You can install 64 bit or 32 as long as it's pro or higher. Not sure what your asking with the x34 ? If your meaning 32 bit by the x34 it's actually represented as x86 😉.
