Hooking bnc cable to tv
IF your TV has a set of three (MAYBE only two) RCA female jacks on the back labelled for Composite Video and Stereo Audio inputs as CountMike has inquired, you are most of the way there. Then you need two items: a common RCA cable with male connectors on both ends, and an adapter to go from an RCA female connector to a BNC male connector, like this
https://www.amazon.com/VCE-Gold-Plated-Adapters-Connector-Security/dp/B072KMZTSX/ref=sr_1_1_sspa?ie=UTF8&qid=1539968763&sr=8-1-spons&keywords=Adapter+BNC+to+RCA&psc=1
Using these you can connect the analog video output of the camera to your TV's Video input jack only. There is no Audio connection to make.
This might or might not work, because the web pages for that camera do not tell us what form its output signal is. A normal TV Video input jack will accept what is known as a Composite Video signal with certain specs for voltage and frequencies on that signal. Unless your camera sends out that type of analog signal, it won't work even though you have a way to convert one cable connection system to another.
