I'm planning to order parts for my new system today from newegg.com just want to make sure everything looks good before i place the order. My budget is $1100 I plan on using this build for all my gaming needs but i will also use this system for college. the only components i dont need is speakers, mouse, keyboard, OS, DVD drives, and monitor. I don't plan on OC'ing the system. I plan on running a 2560 x 1600 resolution on 2 x 24 inch monitors. Thanks in advance for any advice
--Intel Core i5-750 Lynnfield 2.66GHz 8MB L3 Cache LGA 1156 95W Quad-Core Processor Model BX80605I5750 http://www.newegg.com/Product/Product.aspx?Item=N82E16819115215
--ASUS P7P55D-E LGA 1156 Intel P55 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131620
--Seagate Barracuda 7200.12 ST3500418AS 500GB 7200 RPM 16MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148395
--Thermaltake TR2 TRX-750M 750W ATX 12V v2.3 / EPS 12V v2.91 80 PLUS Certified Modular Active PFC Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817153117
I pick this power supply and hard drive because it came in a combo for $94.99 if this isnt a good one i can change it.
--HIS H587FN1GD Radeon HD 5870 1GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814161329
--ZALMAN Z7 Plus Black Steel / Plastic ATX Mid Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811235024
--G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231303
I was suggested this memory from one of the forums but i still have a few questions first is im not OC'ing should is get 1333mhz memory or will 1600 mhz be better, and what timing would be best. If i decided to go with a company ive heard of like Corsair, what timing that would be suggested. The last system i built was about 5 years ago so i don't know all the new players just trying to stay within my comfort zone.
