Alright, here is a bit of back story first...
I got a new desktop a few months back from CyberPowerPC, and it has been working amazingly up until today. I was messing around on Minecraft with some shaders and texture packs, seeing how good i could get it to look, and everything was fine until i went in to full screen mode, then back out of it. A bunch of horizontal lines kept flashing everywhere on my monitor every time something happened on-screen.
*Video for reference*
I tried unplugging my graphics card and plugging it back in, because for some reason i thought that would help... well it didn't. I know for sure it's not my hdmi connection from my computer to monitor, because along side the flickering lines on the screen, some videos will do this, and I know it's not my monitor, because I tried it with another monitor and did the same thing... I also tried to update my drivers from the control panel, but that didn't help either.
Playing games seems fine, with the exception of these really weird dots that are constantly on the screen-
I recreated what i saw on my screen, and the dots in blue are what i found to be the main pattern that is repeated twice horizontally, and 6 or so times vertically- And I should also add that they are transparent, as well- about 15% transparent compared to the ones in the picture.
So I have no idea what I should do. If it's the graphics card, ill go to AMD first, to see if they will replace it, because based on the stories i have heard of CyberPowerPC's support, I would rather eat dirt than have to deal with them... If it's an easy fix, like- "Oh, just try re-plugging this in and it should work.", or "Oh, do this, this, and this, restart and then you should be good.", that would be amazing, but i'm not that optimistic about it.
So what do you guys think? Any help on this would be great!
-Specs-
*There's a lot of info here- But I cut out the unimportant, spammy bits*
-Specs-
Summary
Operating System
Windows 8.1 64-bit
CPU
AMD FX-8350 31 °C
Vishera 32nm Technology
RAM
8.00GB Dual-Channel DDR3 @ 669MHz (9-9-9-24)
Motherboard
Gigabyte Technology Co., Ltd. 970A-DS3P (CPU 1) 28 °C
Graphics
E320-A0 (1366x768@60Hz)
2048MB ATI AMD Radeon R9 200 Series (MSI) 28 °C
Storage
1863GB TOSHIBA DT01ACA200 (SATA) 37 °C
Optical Drives
TSSTcorp CDDVDW SH-224DB
Audio
Realtek High Definition Audio
Operating System
Windows 8.1 64-bit
Computer type: Desktop
Installation Date: 1/21/2014 4:09:40 PM
Serial Number: VTV99-8B6HC-8JQGJ-T4PFV-RGB8V
Windows Security Center
User Account Control (UAC) Enabled
Notify level 2 - Default
Firewall Enabled
Windows Update
AutoUpdate Download Automatically and Install at Set Scheduled time
Schedule Frequency Every Day
Schedule Time
Windows Defender
Windows Defender Enabled
Antivirus
Antivirus Enabled
Display Name Windows Defender
Virus Signature Database Up to date
.NET Frameworks installed
v4.5 Full
v4.5 Client
v3.5 SP1
v3.0 SP2
v2.0 SP2
Internet Explorer
Version 11.0.9600.16518
PowerShell
Version 4.0
Java
Java Runtime Environment
Path C:\Program Files\Java\jre7\bin\java.exe
Version 7.0
Update 51
Build 13
Environment Variables
USERPROFILE C:\Users\Matt
SystemRoot C:\Windows
User Variables
sourcesdk C:\Program Files (x86)\Steam\steamapps\common\SourceSDK
TEMP C:\Users\Matt\AppData\Local\Temp
TMP C:\Users\Matt\AppData\Local\Temp
VProject C:\Program Files (x86)\Steam\steamapps\common\counter-strike source\cstrike
Machine Variables
ComSpec C:\Windows\system32\cmd.exe
FP_NO_HOST_CHECK NO
NUMBER_OF_PROCESSORS 8
OS Windows_NT
Path C:\Windows\system32
C:\Windows
C:\Windows\System32\Wbem
C:\Windows\System32\WindowsPowerShell\v1.0\
C:\Program Files (x86)\ATI Technologies\ATI.ACE\Core-Static
PATHEXT .COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC
PROCESSOR_ARCHITECTURE AMD64
PROCESSOR_IDENTIFIER AMD64 Family 21 Model 2 Stepping 0, AuthenticAMD
PROCESSOR_LEVEL 21
PROCESSOR_REVISION 0200
PSModulePath C:\Windows\system32\WindowsPowerShell\v1.0\Modules\
TEMP C:\Windows\TEMP
TMP C:\Windows\TEMP
USERNAME SYSTEM
windir C:\Windows
Power Profile
Active power scheme Balanced
Hibernation Enabled
Turn Off Monitor after: (On AC Power) 10 min
Turn Off Hard Disk after: (On AC Power) 20 min
Suspend after: (On AC Power) 15 min
Screen saver Enabled
ATI I/O Communications Processor PCI Bus Controller
ATI I/O Communications Processor SMBus Controller
Motherboard resources
PCI standard host CPU bridge
System board
PCI standard PCI-to-PCI bridge
Generic PnP Monitor
High Definition Audio Bus
AMD High Definition Audio Device
1 - E320-A0 (AMD High Definition Audio Device)
VIA USB 3.0 eXtensible Host Controller - 0100 (Microsoft)
USB Root Hub (xHCI)
Generic USB Hub
USB Composite Device
USB Input Device
HID Keyboard Device
USB Input Device
HID-compliant consumer control device
HID-compliant system controller
HID-compliant vendor-defined device
HID-compliand device
HID-compliant mouse
Realtek PCIe GBE Family Controller
TP-LINK Wireless PCI Express Adapter
Microsoft Wi-Fi Direct Virtual Adapter
Standard SATA AHCI Controller
TOSHIBA DT01ACA200
Standard OpenHCD USB Host Controller
USB Root Hub
Standard Enhanced PCI to USB Host Controller
USB Root Hub
USB Root Hub
USB Root Hub
Standard Dual Channel PCI IDE Controller
ATA Channel 0
ATA Channel 1
Realtek Digital Output (Realtek High Definition Audio)
Speakers (Realtek High Definition Audio)
Stereo Mix (Realtek High Definition Audio)
PCI standard ISA bridge
Direct memory access controller
Numeric data processor
Programmable interrupt controller
System CMOS/real time clock
System speaker
System timer
USB Root Hub
USB Root Hub
USB Root Hub
CPU
AMD FX-8350
Cores 8
Threads 8
Name AMD FX-8350
Code Name Vishera
Package Socket AM3+ (942)
Technology 32nm
Specification AMD FX-8350 Eight-Core Processor
Family F
Extended Family 15
Model 2
Extended Model 2
Stepping 0
Revision OR-C0
Instructions MMX (+), SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, SSE4A, AMD 64, NX, VMX, AES, AVX, FMA3, FMA4
Virtualization Supported, Disabled
Hyperthreading Not supported
Fan Speed 1439 RPM
Bus Speed 200.9 MHz
Rated Bus Speed 2411.0 MHz
Stock Core Speed 4000 MHz
Stock Bus Speed 200 MHz
Average Temperature 31 °C
Caches
L1 Data Cache Size 8 x 16 KBytes
L1 Instructions Cache Size 4 x 64 KBytes
L2 Unified Cache Size 4 x 2048 KBytes
L3 Unified Cache Size 8192 KBytes
Cores
Core 0
Core Speed 1406.4 MHz
Multiplier x 7.0
Bus Speed 200.9 MHz
Temperature 31 °C
Threads APIC ID: 0
Core 1
Multiplier x 7.0
Bus Speed 200.9 MHz
Temperature 31 °C
Threads APIC ID: 1
Core 2
Multiplier x 7.0
Bus Speed 200.9 MHz
Temperature 31 °C
Threads APIC ID: 2
Core 3
Multiplier x 7.0
Bus Speed 200.9 MHz
Temperature 31 °C
Threads APIC ID: 3
Core 4
Multiplier x 7.0
Bus Speed 200.9 MHz
Temperature 31 °C
Threads APIC ID: 4
Core 5
Multiplier x 7.0
Bus Speed 200.9 MHz
Temperature 31 °C
Threads APIC ID: 5
Core 6
Multiplier x 7.0
Bus Speed 200.9 MHz
Temperature 31 °C
Threads APIC ID: 6
Core 7
Multiplier x 7.0
Bus Speed 200.9 MHz
Temperature 31 °C
Threads APIC ID: 7
RAM
Memory slots
Total memory slots 4
Used memory slots 2
Free memory slots 2
Memory
Type DDR3
Size 8192 MBytes
Channels # Dual
DRAM Frequency 669.7 MHz
CAS# Latency (CL) 9 clocks
RAS# to CAS# Delay (tRCD) 9 clocks
RAS# Precharge (tRP) 9 clocks
Cycle Time (tRAS) 24 clocks
Bank Cycle Time (tRC) 33 clocks
Physical Memory
Memory Usage 31 %
Total Physical 7.97 GB
Available Physical 5.42 GB
Total Virtual 9.22 GB
Available Virtual 4.73 GB
SPD
Number Of SPD Modules 2
Slot #1
Type DDR3
Size 4096 MBytes
Manufacturer A-Data Technology
Max Bandwidth PC3-10700 (667 MHz)
Part Number DDR3 1866
Serial Number 0000C52F
Week/year 52 / 13
SPD Ext. XMP
XMP-1866
Frequency 933 MHz
CAS# Latency 10.0
RAS# To CAS# 11
RAS# Precharge 10
tRAS 30
Voltage 1.500 V
JEDEC #5
Frequency 685.7 MHz
CAS# Latency 9.0
RAS# To CAS# 9
RAS# Precharge 9
tRAS 25
tRC 34
Voltage 1.500 V
JEDEC #4
Frequency 609.5 MHz
CAS# Latency 8.0
RAS# To CAS# 8
RAS# Precharge 8
tRAS 22
tRC 30
Voltage 1.500 V
JEDEC #3
Frequency 533.3 MHz
CAS# Latency 7.0
RAS# To CAS# 7
RAS# Precharge 7
tRAS 20
tRC 27
Voltage 1.500 V
JEDEC #2
Frequency 457.1 MHz
CAS# Latency 6.0
RAS# To CAS# 6
RAS# Precharge 6
tRAS 17
tRC 23
Voltage 1.500 V
JEDEC #1
Frequency 381.0 MHz
CAS# Latency 5.0
RAS# To CAS# 5
RAS# Precharge 5
tRAS 14
tRC 19
Voltage 1.500 V
Slot #2
Type DDR3
Size 4096 MBytes
Serial Number 0000C534
Week/year 52 / 13
SPD Ext. XMP
XMP-1866
Frequency 933 MHz
CAS# Latency 10.0
RAS# To CAS# 11
RAS# Precharge 10
tRAS 30
Voltage 1.500 V
JEDEC #5
Frequency 685.7 MHz
CAS# Latency 9.0
RAS# To CAS# 9
RAS# Precharge 9
tRAS 25
tRC 34
Voltage 1.500 V
JEDEC #4
Frequency 609.5 MHz
CAS# Latency 8.0
RAS# To CAS# 8
RAS# Precharge 8
tRAS 22
tRC 30
Voltage 1.500 V
JEDEC #3
Frequency 533.3 MHz
CAS# Latency 7.0
RAS# To CAS# 7
RAS# Precharge 7
tRAS 20
tRC 27
Voltage 1.500 V
JEDEC #2
Frequency 457.1 MHz
CAS# Latency 6.0
RAS# To CAS# 6
RAS# Precharge 6
tRAS 17
tRC 23
Voltage 1.500 V
JEDEC #1
Frequency 381.0 MHz
CAS# Latency 5.0
RAS# To CAS# 5
RAS# Precharge 5
tRAS 14
tRC 19
Voltage 1.500 V
Motherboard
Manufacturer Gigabyte Technology Co., Ltd.
Model 970A-DS3P (CPU 1)
Version To be filled by O.E.M.
Chipset Vendor AMD
Chipset Model RD9x0
Chipset Revision 02
Southbridge Vendor AMD
Southbridge Model SB910/950
Southbridge Revision 40
System Temperature 28 °C
BIOS
Brand American Megatrends Inc.
Version F1
Date 4/8/2013
Voltage
CPU CORE 0.876 V
MEMORY CONTROLLER 1.476 V
+3.3V 2.028 V
+5V 3.367 V
+12V 7.872 V
-12V (4.704) V
-5V (8.880) V
+5V HIGH THRESHOLD 2.742 V
CMOS BATTERY 1.608 V
PCI Data
Slot PCI-E
Slot Type PCI-E
Slot Usage In Use
Data lanes x16
Slot Designation J6B2
Characteristics 3.3V, Shared, PME
Slot Number 0
Slot PCI-E
Slot Type PCI-E
Slot Usage In Use
Data lanes x1
Slot Designation J6B1
Slot Number 1
Slot PCI-E
Slot Type PCI-E
Slot Usage In Use
Data lanes x8
Slot Designation J6D1
Slot Number 2
Slot PCI-E
Slot Type PCI-E
Slot Usage In Use
Data lanes x16
Slot Designation J7B1
Slot Number 3
Graphics
Monitor
Name E320-A0 on AMD Radeon R9 200 Series
Current Resolution 1366x768 pixels
Work Resolution 1366x728 pixels
State Enabled, Primary, Output devices support
Monitor Width 1366
Monitor Height 768
Monitor BPP 32 bits per pixel
Monitor Frequency 60 Hz
Device \\.\DISPLAY21\Monitor0
Manufacturer ATI
Model AMD Radeon R9 200 Series
Device ID 1002-6810
Subvendor MSI (1462)
Current Performance Level Level 0
Voltage 0.875 V
GPU Clock 1080.0 MHz
Temperature 28 °C
Core Voltage 0.875 V
Driver version 13.251.0.0
BIOS Version 113-C6310100-X00
Memory Type GDDR5
Memory 2048 MB
Bandwidth 179.2 GB/s
Count of performance levels : 2
Level 1
GPU Clock 300 MHz
Memory Clock 150 MHz
Level 2
GPU Clock 1080 MHz
Memory Clock 1400 MHz
Storage
Hard drives
TOSHIBA DT01ACA200
Manufacturer TOSHIBA
Heads 16
Cylinders 243,201
Tracks 62,016,255
Sectors 3,907,024,065
SATA type SATA-III 6.0Gb/s
Device type Fixed
ATA Standard ATA8-ACS
Serial Number Y39M6TGGS
LBA Size 48-bit LBA
Power On Count 52 times
Power On Time 33.5 days
Speed 7200 RPM
Features S.M.A.R.T., APM, NCQ
Max. Transfer Mode SATA III 6.0Gb/s
Used Transfer Mode SATA III 6.0Gb/s
Interface SATA
Capacity 1863 GB
Real size 2,000,398,934,016 bytes
RAID Type None
S.M.A.R.T
Status Good
Temperature 37 °C
Temperature Range OK (less than 50 °C)
01 Read Error Rate 100 (100) Data 0000000000
02 Throughput Performance 139 (139) Data 0000000048
03 Spin-Up Time 130 (130) Data 0001250122
04 Start/Stop Count 100 (100) Data 0000000034
05 Reallocated Sectors Count 100 (100) Data 0000000000
07 Seek Error Rate 100 (100) Data 0000000000
08 Seek Time Performance 124 (124) Data 0000000021
09 Power-On Hours (POH) 100 (100) Data 0000000324
0A Spin Retry Count 100 (100) Data 0000000000
0C Device Power Cycle Count 100 (100) Data 0000000034
C0 Power-off Retract Count 100 (100) Data 0000000034
C1 Load/Unload Cycle Count 100 (100) Data 0000000034
C2 Temperature 162 (162) Data 0000050025
C4 Reallocation Event Count 100 (100) Data 0000000000
C5 Current Pending Sector Count 100 (100) Data 0000000000
C6 Uncorrectable Sector Count 100 (100) Data 0000000000
C7 UltraDMA CRC Error Count 200 (200) Data 0000000000
Partition 0
Partition ID Disk #0, Partition #0
Size 350 MB
Partition 1
Partition ID Disk #0, Partition #1
Disk Letter C:
File System NTFS
Volume Serial Number 40867DCC
Size 1862 GB
Used Space 235 GB (13%)
Free Space 1627 GB (87%)
Optical Drives
Media Type DVD Writer
Name TSSTcorp CDDVDW SH-224DB
Availability Running/Full Power
Capabilities Random Access, Supports Writing, Supports Removable Media
Read capabilities CD-R, CD-RW, CD-ROM, DVD-RAM, DVD-ROM, DVD-R, DVD-RW, DVD+R, DVD+RW, DVD-R DL, DVD+R DL
Write capabilities CD-R, CD-RW, DVD-RAM, DVD-R, DVD-RW, DVD+R, DVD+RW, DVD-R DL, DVD+R DL
Config Manager Error Code Device is working properly
Config Manager User Config FALSE
Drive D:
Media Loaded FALSE
SCSI Bus 1
SCSI Logical Unit 0
SCSI Port 2
SCSI Target Id 0
Status OK
Audio
Sound Cards
Playback Devices
Speakers (Realtek High Definition Audio) (default)
Recording Device
Peripherals
HID Keyboard Device
Device Kind Keyboard
Device Name HID Keyboard Device
Vendor Unknown
Location USB Input Device
Driver
Date 6-21-2006
Version 6.3.9600.16384
File C:\Windows\system32\DRIVERS\kbdhid.sys
File C:\Windows\system32\DRIVERS\kbdclass.sys
HID-compliant mouse
Device Kind Mouse
Device Name HID-compliant mouse
Vendor PixArt Imaging
Location HID-compliand device
Driver
Date 6-21-2006
File C:\Windows\system32\DRIVERS\mouhid.sys
File C:\Windows\system32\DRIVERS\mouclass.sys
HP Deskjet 3000 J310 series Class Driver
Device Kind Printer
Device Name HP Deskjet 3000 J310 series Class Driver
Vendor HP
Location HP4AD3EF (HP Deskjet 3000 J310 series)
Driver
Date 4-21-2009
Printers
Fax
Printer Port SHRFAX:
Print Processor winprint
Availability Always
Priority 1
Duplex None
Print Quality 200 * 200 dpi Monochrome
Status Unknown
Driver
Driver Name Microsoft Shared Fax Driver (v4.00)
Driver Path C:\Windows\system32\spool\DRIVERS\x64\3\FXSDRV.DLL
HP4AD3EF (HP Deskjet 3000 J310 series) (Default Printer)
Printer Port WSD-1d655c95-850a-433a-9a07-46149e16009d.0036
Availability Always
Priority 1
Duplex None
Print Quality 600 * 300 dpi Color
Status Unknown
Driver
Driver Name HP Deskjet 3000 J310 series Class Driver (v6.03)
Driver Path C:\Windows\System32\DriverStore\FileRepository\ntprint.inf_amd64_64a5c2d136933c8f\Amd64\mxdwdrv.dll
Microsoft XPS Document Writer
Printer Port PORTPROMPT:
Availability Always
Priority 1
Duplex None
Print Quality 600 * 600 dpi Color
Status Unknown
Driver
Driver Name Microsoft XPS Document Writer v4 (v6.03)
Network
You are connected to the internet
Connected through TP-LINK Wireless PCI Express Adapter
IP Address 192.168.1.105
Subnet mask 255.255.255.0
Gateway server 192.168.1.1
Preferred DNS server 192.168.1.1
Alternate DNS server 24.159.193.40
Alternate DNS server 24.205.224.36
DHCP Enabled
DHCP server 192.168.1.1
Adapter Type IEEE 802.11 wireless
NetBIOS over TCP/IP Enabled via DHCP
NETBIOS Node Type Hybrid node
Link Speed 35.8 KBps
Computer Name
NetBIOS Name MATTSPC
DNS Name MattsPc
Membership Part of workgroup
Workgroup WORKGROUP
Remote Desktop
Disabled
Console
State Active
Domain MATTSPC
WinInet Info
LAN Connection
Local system uses a local area network to connect to the Internet
Local system has RAS to connect to the Internet
Wi-Fi Info
Using native Wi-Fi API version 2
Available access points count 1
Wi-Fi (linksys_WPS_5476)
SSID linksys_WPS_5476
Frequency 2437000 kHz
Channel Number 6
Name linksys_WPS_5476
Signal Strength/Quality 98
Security Enabled
State The interface is connected to a network
Dot11 Type Infrastructure BSS network
Network Connectible
Network Flags Currently Connected to this network
Cipher Algorithm to be used when joining this network AES-CCMP algorithm
Default Auth used to join this network for the first time 802.11i RSNA algorithm that uses PSK
WinHTTPInfo
WinHTTPSessionProxyType No proxy
Session Proxy
Session Proxy Bypass
Connect Retries 5
Connect Timeout (ms) 60,000
HTTP Version HTTP 1.1
Max Connects Per 1.0 Servers INFINITE
Max Connects Per Servers INFINITE
Max HTTP automatic redirects 10
Max HTTP status continue 10
Send Timeout (ms) 30,000
IEProxy Auto Detect Yes
IEProxy Auto Config
IEProxy
IEProxy Bypass
Default Proxy Config Access Type No proxy
Default Config Proxy
Default Config Proxy Bypass
Sharing and Discovery
Network Discovery Enabled
File and Printer Sharing Disabled
File and printer sharing service Enabled
Simple File Sharing Enabled
Administrative Shares Enabled
Network access: Sharing and security model for local accounts Classic - local users authenticate as themselves
Network Shares
No network shares
Current TCP Connections
C:\Program Files (x86)\Google\Chrome\Application\chrome.exe (4816)
Generated with Speccy v1.25.674
Operating System
Windows 8.1 64-bit
CPU
AMD FX-8350 31 °C
RAM
Motherboard
Graphics
Storage
Optical Drives
Audio
Operating System
Windows 8.1 64-bit
Firewall Enabled
Windows Update
Schedule Time
Windows Defender
Antivirus
Antivirus Enabled
v4.5 Full
v4.5 Client
v3.5 SP1
v3.0 SP2
v2.0 SP2
Internet Explorer
PowerShell
Version 4.0
Java
Version 7.0
Update 51
Build 13
User Variables
Machine Variables
FP_NO_HOST_CHECK NO
OS Windows_NT
C:\Windows
PROCESSOR_LEVEL 21
TMP C:\Windows\TEMP
USERNAME SYSTEM
windir C:\Windows
Power Profile
Hibernation Enabled
System board
Generic PnP Monitor
USB Root Hub (xHCI)
Generic USB Hub
USB Input Device
HID Keyboard Device
USB Input Device
HID-compliant mouse
TOSHIBA DT01ACA200
USB Root Hub
USB Root Hub
USB Root Hub
USB Root Hub
ATA Channel 0
ATA Channel 1
System speaker
System timer
USB Root Hub
USB Root Hub
USB Root Hub
CPU
AMD FX-8350
Cores 8
Threads 8
Name AMD FX-8350
Code Name Vishera
Technology 32nm
Family F
Extended Family 15
Model 2
Extended Model 2
Stepping 0
Revision OR-C0
Fan Speed 1439 RPM
Bus Speed 200.9 MHz
Caches
Cores
Core 0
Multiplier x 7.0
Bus Speed 200.9 MHz
Temperature 31 °C
Threads APIC ID: 0
Core 1
Multiplier x 7.0
Bus Speed 200.9 MHz
Temperature 31 °C
Threads APIC ID: 1
Core 2
Multiplier x 7.0
Bus Speed 200.9 MHz
Temperature 31 °C
Threads APIC ID: 2
Core 3
Multiplier x 7.0
Bus Speed 200.9 MHz
Temperature 31 °C
Threads APIC ID: 3
Core 4
Multiplier x 7.0
Bus Speed 200.9 MHz
Temperature 31 °C
Threads APIC ID: 4
Core 5
Multiplier x 7.0
Bus Speed 200.9 MHz
Temperature 31 °C
Threads APIC ID: 5
Core 6
Multiplier x 7.0
Bus Speed 200.9 MHz
Temperature 31 °C
Threads APIC ID: 6
Core 7
Multiplier x 7.0
Bus Speed 200.9 MHz
Temperature 31 °C
Threads APIC ID: 7
RAM
Memory slots
Used memory slots 2
Free memory slots 2
Memory
Type DDR3
Size 8192 MBytes
Channels # Dual
Physical Memory
Memory Usage 31 %
SPD
Slot #1
Type DDR3
Size 4096 MBytes
Week/year 52 / 13
SPD Ext. XMP
XMP-1866
Frequency 933 MHz
CAS# Latency 10.0
RAS# To CAS# 11
RAS# Precharge 10
tRAS 30
Voltage 1.500 V
JEDEC #5
Frequency 685.7 MHz
CAS# Latency 9.0
RAS# To CAS# 9
RAS# Precharge 9
tRAS 25
tRC 34
Voltage 1.500 V
JEDEC #4
Frequency 609.5 MHz
CAS# Latency 8.0
RAS# To CAS# 8
RAS# Precharge 8
tRAS 22
tRC 30
Voltage 1.500 V
JEDEC #3
Frequency 533.3 MHz
CAS# Latency 7.0
RAS# To CAS# 7
RAS# Precharge 7
tRAS 20
tRC 27
Voltage 1.500 V
JEDEC #2
Frequency 457.1 MHz
CAS# Latency 6.0
RAS# To CAS# 6
RAS# Precharge 6
tRAS 17
tRC 23
Voltage 1.500 V
JEDEC #1
Frequency 381.0 MHz
CAS# Latency 5.0
RAS# To CAS# 5
RAS# Precharge 5
tRAS 14
tRC 19
Voltage 1.500 V
Slot #2
Type DDR3
Size 4096 MBytes
Week/year 52 / 13
SPD Ext. XMP
XMP-1866
Frequency 933 MHz
CAS# Latency 10.0
RAS# To CAS# 11
RAS# Precharge 10
tRAS 30
Voltage 1.500 V
JEDEC #5
Frequency 685.7 MHz
CAS# Latency 9.0
RAS# To CAS# 9
RAS# Precharge 9
tRAS 25
tRC 34
Voltage 1.500 V
JEDEC #4
Frequency 609.5 MHz
CAS# Latency 8.0
RAS# To CAS# 8
RAS# Precharge 8
tRAS 22
tRC 30
Voltage 1.500 V
JEDEC #3
Frequency 533.3 MHz
CAS# Latency 7.0
RAS# To CAS# 7
RAS# Precharge 7
tRAS 20
tRC 27
Voltage 1.500 V
JEDEC #2
Frequency 457.1 MHz
CAS# Latency 6.0
RAS# To CAS# 6
RAS# Precharge 6
tRAS 17
tRC 23
Voltage 1.500 V
JEDEC #1
Frequency 381.0 MHz
CAS# Latency 5.0
RAS# To CAS# 5
RAS# Precharge 5
tRAS 14
tRC 19
Voltage 1.500 V
Motherboard
Chipset Vendor AMD
Chipset Model RD9x0
Chipset Revision 02
BIOS
Version F1
Date 4/8/2013
Voltage
CPU CORE 0.876 V
+3.3V 2.028 V
+5V 3.367 V
+12V 7.872 V
-12V (4.704) V
-5V (8.880) V
PCI Data
Slot PCI-E
Slot Type PCI-E
Slot Usage In Use
Data lanes x16
Slot Number 0
Slot PCI-E
Slot Type PCI-E
Slot Usage In Use
Data lanes x1
Slot Number 1
Slot PCI-E
Slot Type PCI-E
Slot Usage In Use
Data lanes x8
Slot Number 2
Slot PCI-E
Slot Type PCI-E
Slot Usage In Use
Data lanes x16
Slot Number 3
Graphics
Monitor
Monitor Width 1366
Monitor Height 768
Manufacturer ATI
Device ID 1002-6810
Voltage 0.875 V
Temperature 28 °C
Memory Type GDDR5
Memory 2048 MB
Level 1
GPU Clock 300 MHz
Level 2
GPU Clock 1080 MHz
Storage
Hard drives
TOSHIBA DT01ACA200
Heads 16
Cylinders 243,201
Tracks 62,016,255
Device type Fixed
LBA Size 48-bit LBA
Speed 7200 RPM
Interface SATA
Capacity 1863 GB
RAID Type None
S.M.A.R.T
Status Good
Temperature 37 °C
Partition 0
Size 350 MB
Partition 1
Disk Letter C:
File System NTFS
Size 1862 GB
Optical Drives
Drive D:
Media Loaded FALSE
SCSI Bus 1
SCSI Logical Unit 0
SCSI Port 2
SCSI Target Id 0
Status OK
Audio
Sound Cards
Playback Devices
Recording Device
Peripherals
HID Keyboard Device
Vendor Unknown
Driver
Date 6-21-2006
HID-compliant mouse
Device Kind Mouse
Driver
Date 6-21-2006
Device Kind Printer
Vendor HP
Driver
Date 4-21-2009
Printers
Fax
Availability Always
Priority 1
Duplex None
Status Unknown
Driver
Availability Always
Priority 1
Duplex None
Status Unknown
Driver
Availability Always
Priority 1
Duplex None
Status Unknown
Driver
Network
DHCP Enabled
Computer Name
DNS Name MattsPc
Workgroup WORKGROUP
Remote Desktop
Disabled
Console
State Active
Domain MATTSPC
WinInet Info
LAN Connection
Wi-Fi Info
Channel Number 6
Security Enabled
Network Connectible
WinHTTPInfo
Session Proxy
Connect Retries 5
IEProxy Auto Config
IEProxy
IEProxy Bypass
Network Shares
No network shares
