Horizontal Lines on 2nd Monitor
Hi,
Most probable cause is that You got more vertical frequencies than the monitor is made for.
The graphics card is sending the frames at a certain speed, but also together information with each frame of how to drew them on the monitor.
Faster doesn't necessarily means to be faster, actually.
Ok. That can easily be adjusted in the tools menu > change it to 60 HZ or what ever your monitor is capable of.
Best regards from Sweden
Hi,
my 2nd monitor refreshes at 60hz. I went to my properties for my monitor and it was already set at 60 so i brought it down to 50 which fixed the issue which is weird.
