[SOLVED] horizontal stripes on monitor
Sep 25, 2020
I've recently purchased a new pc:
Gigabyte H410M S2H
Windows 10 Home (64-bit)
Intel® Core™ i3-10100 CPU @ 3.60GHz
8GB RAM
I have vertical lines on my monitor: LG IPS FULLHD 22MP48HQ-P
Cable is HDMI and I also tried VGA
The stripes appear when the picture is static (when it is moving I can't spot it but I assume it's there also)
The monitor worked fine on another device. I did try another monitor (on my current device) and it seemed to work fine (haven't seen any stripes). I have tried all the refresh rates listed 30 59 60 (even tried interlaced) to no avail. I set default setting for the BIOS because when I bought it they accidently put a graphics card there (I should have kept my mouth shut and probably wouldn't have a problem now!). Of course I downloaded all the latest drivers. Also tried running Linux Mint from a usb stick (haven't installed it though).
So I'm out of ideas. what else can I do to solve this problem?
I have reset the bios by jumper and took out the battery. it didn't help.
i was not successful in updating the bios. i will do it next week as we are entering shabbath. thank you.
