I am an aspiring Networking major who happens to find this stuff very interesting, so as much detail as possible would be great. My problem is:
About 5 months ago we picked up a new wireless router for our network. At the time of purchase our network required some type of bandwidth control and I ended up picking up a TP-LINK WR1043ND because our current Linksys router had no DDWRT capabilities and TP-LINK comes loaded with bandwidth-control features. Rather than throwing away or getting rid of our old Linksys router I thought to myself, "I could use this for G-mode only and the TP-LINK for N-mode only to improve throughput." I hardwired the Linksys router into the TP-LINK router and then hardwired the TP-LINK into our DSL modem. So, basically, we have an infrastructure that looks like this:
Wall --- DSL modem --- TP-LINK --- Linksys
The first thing I did was set each wireless router to broadcast on different channels- they're only a few feet apart- and with different SSID names. The second thing I did was disable DHCP on the Linksys router and enable it on the TP-LINK. I added a few clients to the reserved address list on the TP-LINK's config page and then limited the bandwidth to the remaining IP address range. I configured some DoS protection rules, set up the security type and passphrase, chose not to broadcast the SSID name, and then connected three clients to the TP-LINK. Everything went quite swimmingly for about 3 months and then throughput started to get horrible. After this happened I began doing some research and found a few different proposed solutions for making the network more efficient. One person suggested bridging the TP-LINK and DSL modem and another suggested putting the TP-LINK in the DMZ of the DSL modem and then putting the Linksys in the DMZ of the TP-LINK. I haven't tried any of these solutions yet for two reasons: 1.) There are a few things I don't understand and 2.) I didn't want to reverse-engineer the entire network configuration to do something that might not work. So, rather than waste anyone's time trying to do troubleshooting steps and going back and forth between reconfiguring and responding... I thought I might make it easier by just saying exactly what I want to happen and let someone else tell me how THEY would configure everything to be as efficient as possible.
First, could someone please explain to me exactly what bridging is and what it does? Why would bridging the TP-LINK and DSL modem be useful?
Second, what exactly is a DMZ and how do you set one up? I heard that, by doing this, it would give all connections a clearer path through the network. Is that true?
Basically, what I want is to have all administration and protection take place on the TP-LINK because it has a much more inuitive and user-friendly interface than the Linksys and DSL modem. I wanted all traffic to have a straight shot through the DSL modem to the TP-LINK where all filtering would take place. I want the DSL modem to be like it's not even there and set up firewalls and protection on the TP-LINK. I want the Linksys router to broadcast in G-mode only and basically give everything connected to it a clear shot through to the TP-LINK, where I'm hoping I can configure EVERYTHING. Is this a good idea? I want to have the max data rates I can on the TP-LINK (the three clients connected to it require the 300mbps data rates) and the Linksys operating in G-mode is inconsequential- it's just there for everything else to connect to and is only there because there are a few G-only devices needing to connect to the network. I heard that switching the TP-LINK to mixed mode would negatively affect throughput so I thought having these two routers operate in different modes would be best. Is that true? If you had a mixture of G/N devices on a network, where the N-devices require the best possible data rates and throuput, how would YOU configure the network? If anyone can help, please be as specific as possible and I will be eternally grateful for your assistance.
