Archived from groups: alt.games.microsoft.flight-sim (
More info?)
The Aircraft.cfg that Bill mentioned is just a text file. You can edit it
with Notepad.
Phillip Windell [MCP, MVP, CCNA]
www.wandtv.com
"Philster" <philster@easystreet.com> wrote in message
news:111nvvikabsho56@corp.supernews.com...
> Concorde is not the old Microsoft FS version. It's a very nice 3rd party
> GMax. Page can be found @
http://www.fsfrance.com/Projets/Mach2/Download.htm
> Still some bugs in new updated air file. It now allows amazing realistic
> pitch-up landings (@10.5 degrees) however the Virtural cockpit textures no
> longer display. Gauges are fine though.
> About the "hovering tires" when landing: what type of editor would I use
to
> play with the Cfg file to improve tire contact?
> Thank you-
> Phil
> "Phillip Windell" <@.> wrote in message
> news:111mgeh36a8oma3@corp.supernews.com...
> > Is this the old concord model from previous FS's or is it a totally new
> > one
> > that someone created? I'm no familiar with the "project" mentioned in
the
> > subject.
> > When GMax models are created in GMax there is an elevation setting that
> > must
> > be made correctly. If it is too high the wheels won't "reach" the
ground.
> > I'm not sure if there is an "external" way to correct it in the Sim
> > itself.
> > www.wandtv.com
> > news:111lo3bh51ql7b8@corp.supernews.com...
> >> Hi- Plenty of touchdown smoke but no tire contact with the runway.
Tires
> >> seem to hover a scaled 16" above the pavement when landing. Sure looks
> > sad!
> >> How does one adjust the Cfg file (FsFrance Concorde.. or any sim model)
> >> to
> >> allow normal touchdown contact?
> >> Using FS9
> >> Thank you for your advice--
> >> Phil
