Question How are EXTENSION cables compatible with ANY powersupply; but mix and matching different brands of PSU cables is not?
barkersofgeraldine
152
7
4,585
As per title, how is it that extension cables are designed to be compatible with ANY PSU, but when you mix different brands of PSU cables - for example, corsair vs cooler master - you will fry your pc?
pls explain
Extension cables are straight through. Pin 1 to Pin 1 and so on, they in effect do nothing but extend and add a little wire resistance.
PSU manufacturers have not agreed to standardize on modular PSU connectors. If you go back even farther it was MUCH worse.
Effectively DIN connectors
https://www.techpowerup.com/review/axp-supernova-600w/images/psu4.jpg
In-line connectors
https://www.antec.com/product/power/images/hcg1000-gold-pdt01.png
Reactions: barkersofgeraldine
