Hi There Guys
So, let's get right into it. My Motherboard is the MSI Z170A GAMING M5 and it says it has 2 CPU Fan Ports + 3 Case Fan Ports. That's pretty straight forward. I am going to occupy one of the CPU Fan Ports with a CPU Fan, and leave the other one empty. So My Case allows 6 Case Fans (2x120 + 4x140) and I want to have all 6 Case Fans enabled. My Power supply is good, so there is not much to that because it can handle and power all those fans including other components. For the two 120mm fans, they two will be Corsair SP120's and for the four 140mm fans, they will be the Aerocool DS140mm Red. I will leave links to both fans, the motherboard and other parts for more info. So the max amount of case mans my mobo handles is 3, which will be occupied by 3 of the AeroCool DS's, but I also need one more AeroCool DS and both of the Corsair SP120's to be powered. How can I add the remaining 3 Fans to my motherboard when the max can only handle 3? I have Three Remaining fans, how will I add them to be fully powered and working? Please let me know guys - all my trust is in you guys!!
Corsair Fan
AeroCool Fan
Motherboard
Case
Power Supply
Thanks so much guys for putting your time in for helping me
Corsair Fan
AeroCool Fan
Motherboard
Case
Power Supply
