I made a new build recently with a ryzen 2700x in a h200i case. I am having issues with heat being trapped in the case and i've been trying to turn up the speed of the fans all day with no avail. I've had all the fans plugged into the nzxt controller for power and they don't show up in the bios or Argus. I've plugged then all into a silverstone PWM fan hub both with the fan hub connected to the motherboard 4 pin and also not connected. One fan will show up in both the bios and Argus but no matter what changes i make to the fan curve setting it at 100% the fans will not change speed forever stuck at ~650 rpm. Why do these fans refuse to change speed. I've also had a single fan plugged into the 4pin fan header and again while being read by the bios and argus any changes i made would not affect the fan.
