J jpbraf91 May 5, 2018 1 0 10 May 5, 2018 #1 I can get the TV to work both but I can't get the three to work together please help
Solution doolittle May 5, 2018 is it this media player? If your surround has optical input, all you need is an optical cable like this one and you should be good to go. If not, and you only have analog 5.1 input on the surround system you will have to get a converter like this one.
doolittle Splendid Jul 19, 2004 2,095 75 21,490 May 5, 2018 Solution #2 is it this media player? If your surround has optical input, all you need is an optical cable like this one and you should be good to go. If not, and you only have analog 5.1 input on the surround system you will have to get a converter like this one. Upvote 0 Downvote Solution
