How can I connect to console session using remote desktop ..
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.work_remotely (More info?)
I would like to be able to connect to the existing open session in the console instead of loging in again.
I use win2003 server at work, and XP at home. Normally I don't log off when I leave work since I like to come back in the morning and continue where I was. If while Im at home, want to add something to my work and use the remote desktop connection, I always need to log in and a new session is created, then I start with an empty desktop and have to get the applications up before I can continue working. It would be much nicer to connect to the existing session as I left at the office.
Does anyone know what I need to set up/enable?
Run mstsc /v:servername /console
That will start the Remote Desktop Client and will connect to the
console session.
Jeffrey Randow (Windows Networking & Smart Display MVP)
jeffreyr-support@remotenetworktechnology.com
Please post all responses to the newsgroups for the benefit
of all USENET users. Messages sent via email may or may not
be answered depending on time availability....
Remote Networking Technology Support Site -
http://www.remotenetworktechnology.com
Windows XP Expert Zone - http://www.microsoft.com/windowsxp/expertzone
On Tue, 20 Jul 2004 15:35:02 -0700, "Antonio Pulido" <Antonio
Thanks! It works, just as i wanted.. I wonder why they don't add that option as a chechbox in the GUI as well...
> console session.
Hi,
I tried running RD in console mode but found it was still logging me out of
the active session on the host machine. Is there anyway of having the Host
stay active while remotely controlling it from the Remote.
I'm using a notebook to remote control a pc that has Realplayer running with
tv-out that beams the footage to my tv. With RD it's booting the host
computer back to the logon screen which in turn stops the video from being
displayed.
> > console session.
This only works on Windows 2003 Server or higher... XP is limited to
one interactive session, so the host session (console) will be locked
when you connect via Remote Desktop. This is by design.
On Thu, 5 Aug 2004 07:09:02 -0700, "raverboy"
<raverboy@discussions.microsoft.com> wrote:
>Hi,
>displayed.
>> > console session.
Disable the screensaver and it should keep you logged into the rdc session. By default the TS client settings are set to indefinite session length.
Mr IT
I am trying to connect to a Windows 2000/2003 server. I am connected through VPN. I try in 2 different ways. I tried with Dameware and it logs me back to an existing session. Since I lock the server.
I tried using RDC but it creates a new session. It doesnt take me to the existing session. I tried the console mode and still no go x.x
Any suggestions plz. The command I tried is
mstsc -console (then type in the IP addr.)
mstsc /console (then type in the IP addr.)
mstsc /v:<IP addr> /console
Please help
Thank You Stevemagg the /admin seems to work, I could never get into console with /console. You made my day THANKS 😀
it is very simple. for 2003 windows server at first go to
run ---> mstsc /admin
pls use mstsc space /admin it automatically connects to the console session.
