• Now's your chance win big! Join our community and get entered to win a RTX 2060 GPU, plus more! Join here.
    Pi Cast Episode 3 streams live on Tuesday, August 4th at 2:30 pm ET (7:30 PM BST). Watch live right here!
    Catch Scharon on the Tom's Hardware Show live on Thursday, August 6th at 2:00 pm ET (7:00 PM BST). Click here!
Question How can i fit 3 fan in a single 4pin fan header
Apr 5, 2020
18
I want buy a SUPERCASE RA08A RAIDER which has 3 fan, but my motherboard (ASROCK H410M-HDV) has only one 4pin fan header. Will i be able to connect all the fans on my pc?
popatim
The Chasis fan header supports up to 2A work of fans. You'll need an appropriate fan splitter cable. I dont see which types (if any) fans are included with the case so please be sure you get the right ones. If it comes with rgb or a-rgb fans then you will need to purchase the correct controller. Again the website for the case make no mention of any fans being included. https://www.supercase.gr/product/supercase-raider-series-ra08a-case/
Reactions: GiorgosGe
Apr 5, 2020
18
The site that i am going to buy the case from, says that it includes 3 fans eco 256c led. It also says that it has led buttom control but idk what that means. My psu also has 3 molex cables.
