Question How can I protect the battery in my AirPods Pro ?
ryann39
184
Hi
I recently got AirPods Pro and I had a few questions about the battery/charging.
I was wondering if there is a certain way I should charge the Airpods case or the actual buds? I don’t want to damage the battery and I don’t know when I should charge the actual case, and if it’s okay to keep popping them back in the case after each use.
I have optimized battery charging on the case, but I am still wondering about charge cycles, and discharges and stuff like that.
What are the main things I should follow to extend battery life?
The main thing you should follow are the instructions in the User Guide.
Doing anything else may void warranty at best and damage the Airpods at worst.
https://support.apple.com/airpods
That said, knowing that many User Guides/Manuals are not all that end user "friendly" there still may be some unanswered questions.
Contradictory/confusing information for example.
Then you may need to delve into the manufacturer's FAQs and Forums.
Key is to get a definitive answer in writing via, in your case, Apple.
