I have T-Force Delta DDR4 RAM (8GBx4) and the best ARGB settings have been the default out-of-the-box. Unfortunately, I changed this with software I downloaded for my ASUS motherboard, as well as with OpenRGB software. Although I can sort of instruct them to revert back to the default rainbow scrolling (it is somewhat different from the various sorts of rainbow scrolling that are created by these programs) it's not exactly the same as the default once was.
At this point, the main difference is that it takes longer for the ARGB to start up when the computer is booted from off. The rainbow used to start immediately at the same time as my other RGB hardware components (the rainbow of each stick is also randomly and completely desynced from each other, which is fine by me for purposes here).
Now, the RAM briefly flashes white when it used to start fully. The a couple seconds later, the default rainbow pattern starts up but it is synced with each stick. The rainbow quickly unsyncs, as the default rainbow speed of each stick is different (again, this is fine by me).
I have, with extreme difficulty, installed and uninstalled the ASUS motherboard RGB softwares Armoury Crate and Aura Sync multiple times (even cleaned registries). The slightly modified RAM performance at startup and in general remains.
The startup RAM pattern appears to finish when the BIOS is still loading. The RAM will light up into the rainbow if I hit Del or F2 to get into the BIOS before Windows starts. Therefore, I am unsure if reinstalling Windows would fix the behavior.
Where are the RGB settings for motherboard RAM stored? In Windows? In the BIOS? Would resetting my BIOS also reset my RAM performance to the complete out-of-the-box original state? (My prebuilt PC arrived with many things in my BIOS well customized, so I am reluctant to try unless I'm sure it will work). There is a BIOS setting specifically for RGB but changing it never affects anything; I believe it is for RGB on the motherboard itself (mine has none) and not the RAM.
