How connect headphones to sound card??
danhakhavro
4
Hallo!
I have hyperx cloud 2 headphones and Asus Xonar DX/XD 7.1 Sound Card PCIe.
I can use my headphones in usb but i think the some quality is not the same if i connect them to my Asus Xonar sound card.
My problem is, i have just 1 input in my headphones but in sound card i need too input 3 how that is possible? I need to buy some adapter?
Some fotos os my problem:
Thank you for any help.
As others have said the hyper x cloud is not a true surround headset, it has two drivers one for each ear. A surround headset would have several drivers in each ear, in my opinion true surround headset's are awful for everything other than distinguishing where footsteps and such are coming from. The box is advertising virtual surround which in my opinion is also awful, it ruins the sound quality for slightly better positional audio.
Configure your audio output for stereo sound only.
Go to control panel -->Hardware and Sound --> Sound --> Select playback device -->configure -->stereo.
It might be a bit different depending on the audio device/ driver you have but you should be able to configure the device for stereo output only.
That will hold you over until you can find one of these:
http://www.milestek.com/p-13247-35mm-stereo-female-to-2-rca-male-6-y-cable.aspx?gclid=Cj0KEQiAot_FBRCqt8jVsoDKoZABEiQAqFL76FG6_QbMBzUF8EQe3I__jg_9BxSUSTeriTiXSG_y5bAaAg-c8P8HAQ
Thanks for you Answer Garilia.
I can connect my headphones to channel n1 and its work, the problem is i have no surround sound efect.
Thanks for the link, this is what i searching, but 1 question, whit this cable surround sound will working? Or i need to buy another cable?
You can't get surround sound from stereo headphones, That's what you have-stereo headphones..
Your headphone has a virtual surround, that is, it's emulated by the chip in the usb adapter and it bypasses your sound card.
Try searching for the Dolby Headphone on the Xonar software.
