How dangerous can using an UPS be?
yamas111
18
I was thinking about buying a UPS to help against brownouts, but I read that there's some danger to UPS. I saw this
http://njnnetwork.com/2010/03/your-ups-battery-backu-may-be-killing-you/
And it worried me a bit.
How much danger do I have to worry about when using an UPS for a home computer system?
The biggest danger from uninterruptable power supplies is that they sometimes catch fire. This is not a common occurrence at all (thankfully) but unlike an AC mains circuit which has breaker, there's no internal mechanism to put out a battery fire. I've only seen one UPS catch fire and the user had placed documents on top of it which caused it to overheat.
The gaseous emissions from the lead-acid battery are not harmful in the...
Wat? Since when did NiCad batteries use sulfuric acid -- hint *never* and even lead acid batteries are quite safe, ask your car.
I have a UPS on every computer, which includes 8 in just my office -- and I'm still alive and fairly old, but healthy. 😀
The gaseous emissions from the lead-acid battery are not harmful in the quantities that they are emitted at as long as the environment is ventilated. Running a UPS in an unventilated broom closet would be an issue, using one in an office would not.
As always, read the manual.
Furthermore, purchase a UPS from a reputable manufacturer. I personally love the APC ones.
Yup. Plus they have an awesome lifetime equipment warranty which insures against damage to the attached devices should the UPS fail to block a surge.
What about CyberPower? I'm wondering because the prices for that brand look a bit cheaper with good reviews still.
Thanks for the help about how legit that article is.
Modern PSUs with active PFC really aren't too fond of the stepped square waves output by most cheap UPS units (including APC). You can buy a true sinewave UPS, but those are a lot more expensive. My understanding is that Cyberpower uses a clipped triangle (I don't own an oscilloscope to test personally), which crosses the -0- line similarly to the way a sinewave does, instead of "lingering" there like a stepped square. As a result, PSUs treat it more like regular AC and are less electrically stressed. These Cyberpower UPS units are much cheaper than APC true-sine units, and in my experience, work as well. One thing that makes Cyberpower cheaper is that they use smaller batteries, which means lower run time. I have two of them, and that has never been a problem.
I've never had a PSU disagree with a UPS over the shape of its output waveform and I've been using them for years. The only time where it panics is when I kick my PC into top gear by running IBT and Furmark at the same time. This draws more current from the PSU than it can provide on battery.
I have a Delta-built Antec SG-650, that will shut off instantly on an APC Back-UPS, but runs flawlessly with either an APC true sinewave unit (I forget the model; my father has it now) or on a Cyberpower APFC unit. My father has it now, because his Earthwatts is also picky. I have read that Delta is more sensitive to waveform than others, e.g. Seasonic.
What's your source for the reviews? If it's store reviews don't read too much into those - a lot of junk products get inexplicably high ratings thanks to store reviews.
And yeah any website that says "Your UPS might be killing you - here's some links about Bob Dylan!" I would think would not qualify as a serious tech website. :lol:
