D Decadent33 Honorable Sep 23, 2012 16 0 10,510 Nov 1, 2014 #1 How do I boot from a USB drive with Biostar G41D3+ motherboard? I cannot find it in the boot sequence list. I'm using a Windows 7 .iso on a correctly formatted usb drive. Any help would be appreciated
Solution USAFRet Nov 1, 2014 Either the USB is not correctly configured, or the motherboard does not support booting from USB.
P Paul NZ Polypheme Sep 15, 2014 20,774 3 61,010 Nov 1, 2014 #2 Well if it isnt then you cant use it to boot from Upvote 0 Downvote
USAFRet Titan Moderator Mar 16, 2013 178,498 21,381 184,590 Nov 1, 2014 Solution #3 Either the USB is not correctly configured, or the motherboard does not support booting from USB. Upvote 0 Downvote Solution
reedo_43 Splendid Feb 18, 2010 6,195 3 29,965 Nov 1, 2014 #4 try changing the usb emulation type to hdd and try again. Upvote 0 Downvote
RAIDENGTK Sep 17, 2019 1 0 10 Sep 17, 2019 #5 Go to Hard Drive BBS Priorities and check your boot options, if you see PMAP in the options, change to it and make sure it's your first boot option. Upvote 0 Downvote
