L Lutalica Jul 20, 2019 2 0 10 Aug 12, 2019 #1 Hello, this will be my first build so while I am buying the parts,I am also doing research so there is one thing that I couldn’t find it by myself. I have B450M Mortar motherboard.If I buy 4 pin fan will I be able to adjust fan speeds?
Solution Barty1884 Aug 12, 2019 Yes, and 4pin fan by default has PWM control. Most 3 pins fans can also be DC controlled by modern motherboards too.
Barty1884 Retired Moderator Apr 16, 2015 22,250 1,350 108,740 Aug 12, 2019 Solution #2 Yes, and 4pin fan by default has PWM control. Most 3 pins fans can also be DC controlled by modern motherboards too. Reactions: Lutalica Upvote 0 Downvote Solution
L Lutalica Jul 20, 2019 2 0 10 Aug 12, 2019 #3 Barty1884 said: Yes, and 4pin fan by default has PWM control. Most 3 pins fans can also be DC controlled by modern motherboards too. Click to expand... Thank you for your answer. Upvote 0 Downvote
