How do I clone two laptops without removing the hard drives?
Sanam3
Hi folks,
I have two identical HP EliteBooks 8440p, one of which works fine. I want to clone the working laptop's hard drive to the other laptop's hard drive without having to remove the two HDDs. Is it possible/how can I do this?
Thanks!
This depends on what exactly is broken on the broken laptop. Will it boot from a CD/DVD?
And no, a Linux LiveCD won't work. See CloneZilla to do that.
Can I try this though? I clone working laptop's HDD to an external HDD. I then take the external HDD and clone that to my other laptop's HDD.
If it will work, can you advise me on doing it with a Linux LiveCD?
I'm on a time crunch, so I'm not in the position to buy a USB to SATA cable, let alone find the one I have. D:
I do agree about the SSD part. I upgraded my home-PC to a ADATA 32 GB SSD and set up symlinks. However, the laptops I'm working with aren't that special enough to deserve SSDs.
Alright, I'll take a look at Clonezilla. The broken laptop will still boot CD/DVD or USB media! Otherwise, will CloneZilla work with the idea I proposed?
Probably. Be prepared to lose whatever exists on the external drive.
And then you will eventually run into the Windows licensing issue. Different motherboards....
Hmmmmm..... They're the same hardware in and out. I'll just back up ext HDD. Licensing... should not be an issue now that I think about it since I'm doing the cloning for my school's IT department. It'll just be a VLK, and since both laptops are school laptops, it should be fine.
