I got a XFX GeForce 8500 GT today and I put it in my computer and had a look at it and could figure out where/which cable goes where. There's 2x 1 row/ 2 pins on the graphics card but no 2 pin cables that are with the Powersupply. Please Help
Your graphics card does not use auxiliary power, all power it needs comes from the PCIe slot itself. The header you're describing is likely a fan header for cooling options (seems XFX didn't see the need for a fan).
Summary: No power supply connection required
