JavaScript is disabled. For a better experience, please enable JavaScript in your browser before proceeding.
You are using an out of date browser. It may not display this or other websites correctly.
You should upgrade or use an
alternative browser .
Okay so I'm building a new PC but I don't know where I'm supposed to connect these cables to. My PSU doesn't have any molex cables. I've got 3 of these fans. This is my first time so I have no idea what I'm doing. Images:
View: https://imgur.com/a/b0KRHM7
What PSU did you have? usually most of the PSU have the 4-pin molex connectors.
For 1st picture, you can connect the left (2pin) and middle (4-pin) into the 4-pin molex connector from the PSU.
For the 2nd picture, you can connect these 3-pin cable into the MB fan_header.
I'm certain my PSU doesn't have these connectors. I've bought SATA to molex adaptors, will that work?
yes, it will work.
A 500W psu from beQuiet, can't find the model or anything though.
