Hi.
Can anyone help with the following please?
I have two Sony SRS-HG1 portable speakers which are currently connected to my main home wifi network and are controlled via an app on my Samsung tablet. The speakers can be and are configured for Wireless stereo operation. They are paired on the wifi network, with one for left channel the other for right channel.
A wireless connection is required for this configuration and the speakers are controlled with the Songpal App. It only requires an internet connection to stream from Spotify or other music streaming sites and for any firmware updates that the speakers require.
For my normal use I don't really use the streaming sites, I connect my media player to one of the speakers via an audio cable and the wireless stereo function is controlled via the app on the tablet across the wifi network.
I would like to know the best way to create a local private wireless network using a battery/usb powered portable wifi router so that I can use it with the above configuration anywhere. I don't want an internet connection or ISP involvement with this "go anywhere" configuration. The wireless network range only needs to be about 5-10 metres.
Can anyone also recommend a suitable portable wireless router that I can use to achieve the above setup?
Thanks in advance for any help.
N
N
