How do I delete a second operating system
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
I've reinstalled windows xp pro to start over.
But everytime the computer starts up I get a screen
giving me the option of one or the other operating systems.
both are xp pro. How can I delete the old one.
I believe that is resolved by Run-->Msconfig-->Goto Boot.ini tab-->Click on
'check all boot paths'
David Nimon
dnimonREMOVE@##sympatico.ca
"Brandon" <Brandon@discussions.microsoft.com> wrote in message
news:FD0A5CBC-963A-40D4-A702-17B875BE89D2@microsoft.com...
Hi
Please see if the following article by Michael Stevens helps:
"I have two installations of XP on the same partition, how do I remove the
one I don't need?"
http://michaelstevenstech.com/xpfaq.html#two
Will Denny
MS-MVP Windows Shell/User
Please reply to the News Groups
If you want to start over? Go back to square 1 and start over.
Reformat your drive and then install. XP will not install over
an old install unless you do a repair install, which is something
different than you are trying to do.
