Monitor: Vizio V655-J04
PC: GTX 980ti, Intel core i7-6700k
Connection: HDMI port into HDMI 1 on tv
Problem 1: No sound on HDMI input
Problem 2: No option to change to 4k resolution in NVIDIA control panel settings.
There is sound working on the TV because it works in the smartcast app input but not on the hdmi 1 input.
I've also tried different hdmi ports and they all have the same issue. I also know the HDMI cable works because I was just using it yesterday on a similar 4k TV and had no issues with it.
I've tried factory resetting the TV and disconnection and reconnecting the hdmi cable.
I checked the device manager and see that the TV could be set as an output but it's greyed out and can't be selected as the default audio output for the pc. I believe this may be the fix but I don't know how to enable it.
Any help is appreciated.
[EDIT] Problem has been solved.
