Question how do i fix my cpu boot problem error code ndis.sys
Nov 25, 2022
i had a i5 9600k and i decided to put an i7 9700k in, my mother board is a asus z390
i put the part in and it loaded me into the bios, i boot into my pc fine after that, i was playing around for about 10mins then blue screened, the error code was ndis.sys and did nothing after that so i turned it off and on again, it didnt let me login it only let me trouble shoot from a "safe" aera i guess you would call it, basically all i can do is reset the pc from here and some other stuff, im not very tech savvy so i dont want to fiddle with stuff i dont know about
thankful if you could help
Colif
Win 11 Master
61,273
5,218
166,290
10,459
you might need to reset the CMOS battery to get motherboard to realise you have a new CPU
ndis is network drivers. Try starting PC with no wifi or ethernet cable attached
still need to update the lan drivers probably
