Question How do I fix the audio input plug if it falls out??
tylego24
9
I bought this case a while back:
https://www.newegg.com/black-phanteks-enthoo-pro-atx-full-tower/p/N82E16811854003
Anyways long story short I ended up tipping over my computer tower on my desk and while there were obvious damages like the window; despite all laws of logic and reason, my silver audio input socket fell out and now my audio is screwed because i can't put it back in securely. As in, it's completely loose. If anyone who has this case has run into the same problem, please let me know how you fixed it.
I have worked with the case but I've never had the issue on it nor on any other cases(even if they were the cheapish chassis' out there). You could contact Phanteks and see if you can get a replacement front panel module to work with. Outside of that you should look at an aftermarket front panel unit or a new case.
