[SOLVED] How do i get 144hz on my monitor?
Krissu3212
Commendable
Oct 28, 2019
14
Hello,
I bought a AOC C24G1 monitor and by default it is set to 60hz. I can't find the setting to turn it to 144hz from the monitor's menu (OSD).
Do I need some kind of software? I already tried to install software from AOC's site but i don't know which driver I should install.
I installed an app called Screen+ from their site but it won't start when i click on it.
Any help please?
Yea the refresh rate is controlled via the OS, not the monitor. Stuff like Freesync or Gsync though is enabled with the card software and OSD on the monitor.
You can test your refresh on this site (no download required).
