A ajburp Oct 15, 2018 4 0 10 Oct 23, 2018 #1 I have connected my monitor to my PC using HDMI but when I select the monitor as the playback device no sound comes out. The monitor is AOC G2590VXQ 24.5"
Solution popatim Oct 25, 2018 Pressing the > button on the monitor should bring up the Volume slider, make sure it isn't all the way down.
popatim Titan Moderator Dec 2, 2009 39,129 1,040 136,890 Oct 25, 2018 Solution #2 Pressing the > button on the monitor should bring up the Volume slider, make sure it isn't all the way down. Upvote 1 Downvote Solution
A ajburp Oct 15, 2018 4 0 10 Oct 26, 2018 #3 popatim : Pressing the > button on the monitor should bring up the Volume slider, make sure it isn't all the way down. there is no button like that on the monitor Upvote 0 Downvote
popatim Titan Moderator Dec 2, 2009 39,129 1,040 136,890 Oct 27, 2018 #4 Try the joystick thing on the back right of it. Upvote 0 Downvote
