[SOLVED] How do i increase my CPU bus speed?
Feb 4, 2023
I have an i3 10100f, and i can't overclock just changing the multiplier, but it's possible to adjust CPU bus speed?
And if it's possible, how do I do it?
(specs)
i3 10100f
RX 6600 XT
700w psu
16gb ddr4 2400mhz
(specs)
i3 10100f
RX 6600 XT
700w psu
16gb ddr4 2400mhz
https://www.techpowerup.com/review/intel-core-i3-10100/20.html
With Comet Lake, and Z490 specifically, Intel marketing made some noise about the new ability to independently adjust BCLK from PCIe clock. In reality, this doesn't do anything for non-K processors because all locked CPUs will measure the BCLK they are running at to simply refuse booting if BCLK is 103 MHz or higher.
(specs)
i3 10100f
RX 6600 XT
700w psu
16gb ddr4 2400mhz
Reactions: mouragab
sycoreaper
311
98
12,720
That CPU is holding back the your 6600. You really should consider upgrading. Deals on new hardware and used I being basically given away even if it's a tad older like 11th or 12th Gen Intel or AMD equivalent.
Reactions: mouragab
