R Renee S B Reputable Oct 24, 2014 1 0 4,510 Oct 24, 2014 #1 I want to purchase a monitor on-line. What is the name of the "feature" that is the mounting panel on the back of the monitor that allows it to be mounted on a monitor-arm?
Solution nukemaster Oct 24, 2014 You look for a VESA mount. It is generally easy to spot as it is a square bolt/screw pattern on the back of the screen. Some monitors are already installed on this mount and the stock support stand has to be removed.
kanewolf Titan Moderator May 29, 2013 38,642 3,806 156,790 Oct 24, 2014 #2 You should look for "VESA mounting" listed somewhere in the specs. Upvote 0 Downvote
nukemaster Titan Nov 23, 2004 19,623 6 74,965 Oct 24, 2014 Solution #3 You look for a VESA mount. It is generally easy to spot as it is a square bolt/screw pattern on the back of the screen. Some monitors are already installed on this mount and the stock support stand has to be removed. Upvote 0 Downvote Solution
