[SOLVED] How do I know if a built-in wifi in motherboard will work with my wifi connection?
May 18, 2018
17
So Im planning on getting this motherboard : https://www.newegg.com/Product/Product.aspx?Item=N82E16813145067&Description=gigabyte h370 aorus gaming 3 wifi&cm_re=gigabyte_h370_aorus_gaming_3_wifi-_-13-145-067-_-Product
And it says built in wifi, so I looked around the internet to check more about it and someone said sometimes wifi connections are not compatible with the built in wifi in a motherboard or something like that.. and then it can cause bad internet connection and stuff. dont really remember. how can I check it will work well together? also an explanation would be nice cuz i have no idea what im talking about
