How do I know if my Motherboard will get enough power?
Qura
Hello,
I'm putting together my first computer server so I'm a bit nervous working with the hardware.
I have a Supermicro MBD-X9DR3-LN4F+ Motherboard with 1 Intel Xeon 2630, 2 4Gb Ram sticks, 1 NVIDIA Geforce 9800 GTX+, and 3 case fans plugged into it.
The motherboard manual says that I need to have both 8-pin connections filled, but the motherboard itself has a warning that says "For Heavy Load Configuration, Make Sure Both 8-Pin Connections are Filled."
My PSU only has one 24-pin Connector and one 8-pin connector, seeing as how the motherboard supports up to 2 CPUs and 24 RAM sticks (not to mention 5 more PCI-E slots), am I safe with just the 24-pin and 8-pin connected? If so, is there a particular 8-pin I should fill first?
Thanks in advance.
Motherboard: http://www.newegg.com/Product/Product.aspx?Item=N82E16813182346
CPU:
http://www.newegg.com/Product/Product.aspx?Item=N82E16819117269
Graphics Card:
http://www.geforce.com/hardware/desktop-gpus/geforce-9800-gtx-plus
Power Supply:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371015
Be sure to connect these power supply connectors to the 24-pin (JPW1) and two 8-pin power connectors (JPW2,
JPW3) on the motherboard. Failure to do so will void the manufacturer warranty on your power supply and motherboard. (page 1-13 of manual) I assume they believe you are using their chassis with its power supply.
What Chassis for EE-ATX motherboard are you using? Using one CPU would mean half of the motherboard wouldn't work (memory slots, PCIe slots).
That's correct. So far I'm only using CPU Socket-1, 2 RAM slots off of CPU Socket-1 and one PCI-E slot on CPU Socket-1. Obviously if I was going to slot another processor I'd want to buy a larger power supply, but I'm wondering if I can work around it for now.
The case is the Corsair Obsidian 800D:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811139001
I picked it up second hand for cheap so I had to drill new holes for the mounting screws to fit the form factor of the EE-ATX, but it fits nicely and has good cable management and air flow.
I had looked into their proprietary chassis but I couldn't justify spending $600+ on a case right now. Do you think that's going to cause problems?
