I'm trying to setup VPN using pfSense, and am running into issues connecting. I think I don't know what I'm doing when it comes to setting the WAN IP. I have watched a number of videos and read through countless documents, and I'm getting some conflicting info (probably because the end solutions for each vid/doc are slightly different).
I can set the LAN IP, I can connect to the web config and set the VPN users, but I can't connect with my VPN setup and I think the problem is my WAN IP.
I saw that the WAN IP "should be an unused IP outside of client range". Does this mean I need a block of static IP's from my ISP, so I can use one of those? If I set the WAN to DHCP, how do I find out what that IP is?
