how can I tell which computer case will fit my new build exactly so that I can avoid overspending on a size that is larger than needed? and, equally, to avoid wasting money on a case that is too small and won't accommodate my new build or if it does, that it won't have enough room for proper air flow or extra fans?
Also how do I know which PSU I need exactly? Is it enough to look at the power consumption of every single component in my new build and add them all up and get a PSU that supplies just that amount? Or a little over?
And while I'm at it, is it okay to get storage drives (including main drive) of different physical dimensions? Like, I just realized my main SSD is 2.5" and my storage / back-up HDD is 3.5". if I get a case that fits the 3.5", will the 2.5" SSD fit nicely?
