I have 6 fans connected to a controller (image bellow), and the controller is connected to CPU OPT in my mobo
My 2 AIO fans are connected directed to the CPU FAN with a splitter
I've been using this controller for 1 year, first with my previous build (i7 10700) and since august with my current one (R7 7700), my case fans always ran at lower speed and noise until a few days ago. I boot my PC and they were loud, full speed, I reboot and fixed, but after a few days the problem came back.
Today I opened my case and changed the connection from SYS_FAN to CPU OPT, I did this because it was how I used with my i7, and even tho it was running fine connected to SYS_FAN until the problem started, for some reason my mobo wouldn't recgonize my case fans through the BIOS.
After changing the connection, it boot running at low speed again, with my BIOS recgonizing the controller, running at ~800RPM just like my CPU_FAN.
Until I tried to update my AMD chipset to deal with another problem I been having, mid install my fans started to run at 1800rpm again, very loud and annoying.
What bothers me is that until very recently my case fans always ran at low speed, both with my i7 and my Ryzen, connected to both CPU OPT and SYS FAN, so there's some culprit changing the speed on my mobo.
I tried to troubleshoot messing with QFAN options on my BIOS and using Armoury Crate, to no results, even tho my mobo recgonize the CPU OPT Fan connected, I can't configure it like I can with CPU Fan and Chassis Fan (note that previously connected on SYS FAN it wouldn't appear on the BIOS, so it was the same 0 RPM for 3 options)
