[SOLVED] How do i solve the white EZ debug LED?
Jan 3, 2021
I have recently switched from a MSI a320m - A PRO to a B450M Pro VDH - MAX and now my pc won't boot to windows, it boots to bios recognises the CPU but won't boot to windows. I've tried re seating the RAM jumpstarting the pc using the motherboard connectors using the Ryzen 3 1200 and even booting with a windows USB and nothing
Time to make a memtest86 boot disk and test your ram for stability. If you cant even run the windows installer USB then I'm suspecting your ram or timings aren't currently 100% compatible. https://www.memtest.org/
i typically begin it when I go to bed and then check on it when I get up 6-8 hrs later. Any errors and you have ram issues.
Latest posts
